Wrong y direction when homing
Hello. Please help me, I do not now what to do: when homing y axis move in pozitive direction and x axis in negative direction. Both end stop are in negative direction. I have a diy laser with MKS DLC 32 V2
If the direction keys in Lightburn work correctly, I’d suggest changing $23. Otherwise you can change $3.
If you’re using Lightburn, do this through Edit → Machine settings… it’s in you native language there…
Make sense?
Yes, thank you.I will try
