Is it possible to add the option of adding X and Y offsets to a selected cut/layer?
It is already possible to add a Z offset to a cut/layer.
I need it to be able to control a second tool(marker/airbrush) which is located at an offset to the laser
and run it as first layer before running multiple laser cuts/layers.
Also having the possibility to add custom start and end g-code to a cut/layer would be awesome.
If you are utilizing a controller supportive of a “Laser 2”, then you would be able to define that laser’s (in this case your second tool’s) offset globally and subsequently map any layer to Laser 2. Does your controller support a 2nd laser?
Sadly this option doesn’t seem to exist for Marlin.
