# X axis drift apparent at higher speeds
**URL:** <https://forum.lightburnsoftware.com/t/x-axis-drift-apparent-at-higher-speeds/186618>\
**Tags:** ruida\
**Created:** [January 9, 2026, 3:51pm UTC](https://forum.lightburnsoftware.com/t/x-axis-drift-apparent-at-higher-speeds/186618 "2026-01-09T15:51:56Z")\
**Showing post:** 5
**Post date:** [January 10, 2026, 12:08pm UTC](https://forum.lightburnsoftware.com/t/x-axis-drift-apparent-at-higher-speeds/186618/5 "2026-01-10T12:08:26Z")
> [@Dannym](#):
> using the same active edge
Good catch!
More details on what to check:
> [@Image shifting and bunching up but cut out is OK](https://forum.lightburnsoftware.com/t/image-shifting-and-bunching-up-but-cut-out-is-ok/145984):
> Red-Black 90w Laser Ruida controller engrave 400mm/s 25% Fill 450mm/s 20% Cut 25mm/s 65% Birch ply held down pins belts are tight so are stepper motors When doing a engrave/fill and cut I get the fill shift while the engrave bunches up, cut out in just fine. This is repeatable, and all come out the same, like it was meant to be, how do I attach image?
> [@Dannym](#):
> might just be backlash
AFAICT, the `Scanning Offset Adjustment` corrects for the constant-ish time delay through the HV power supply that causes a linearly increasing offset with speed.
Mechanical backlash would be constant with speed, so the offset would remain the same. I _think_ the `Initial Offset` value could compensate for backlash, but it’s likely to decrease linearly with speed.
_[View the full topic](https://forum.lightburnsoftware.com/t/x-axis-drift-apparent-at-higher-speeds/186618)._
