on start-up the x-axis automatically starts and goes right all the way to the rail and continues to try to run it will not stop or pause with any buttons? what is wrong
A couple of things come to mind.
Since your engraver starts moving on start up, i’d assume it’s trying to home.
Is the engraver head moving toward a limit switch?
If it’s headed toward the switch and it gets to the switch and keeps pushing on it - the switch could be positioned incorrectly, defective or plugged in to the wrong port. I have also seen a few posts about static electricity in the limit switch causing problems with the controller but it’s much less common.
If it’s moving the wrong way (away from a limit switch) there are software and configuration issues to consider.
Can you share the assembly manual here?
I do not have limit switches, i did change computers but it works perfect with grbl
Disable “Auto-home on startup” in your Edit->Device Settings.
