X axis shifting randomly ruida controller
I have been experiencing this problem recently is has got progrssively worse, now it is happening randomly on every other job.
Can anyone tell me what might be happening here ? Ruida controller, 40watt
It has the look of a grub screw being lose in the pulley.
It recovers after being off completely so it appears to me as a mechanical issue.
Usually if a machine loses track of where the head is, it never recovers, this seems to recover and would indicate mechanical as the most likely issue.
Do a good inspection of the mechanics. With a grub screw it might be easier to just try and tighten it.
Jack’s suggestion is worth reviewing.
However, whenever I’ve seen similar circumstances this tends to end up being a communication fault.
How are you connected to the controller and how reproducible is this?
