X Nema motor wont work
Done a new build with Annoy tools Board double Y axis (newish to game) The build is A1 all brand new The X Axis just makes a little noise doesn’t do anything all the cables are okay and swapped motors around all A1 Any help…
You can make the motor do that by mixing up two wires. The motor will move back and forth 2.8 degrees and appear to do what you describe.
The stepper motor is +A and -A and +B and -B. Reverse the pins on either the A winding or the B winding.
Feel free to test with test leads, patch cords or protoboard leads as needed.
Much easier than doing it for real and easier to repair if you want the motor to go the other way.
Cheers John i had friend come who is tech dude he swapped and swapped and changed things that are beyond me and tested the Board and he told me the board is the problem so i have sent it back to china today, I don’t why i have something in my head If the double Y axis was working A1 but the X only Making a noise not enough power to it sorry if im Losing you should stick to Football.
