X Tool stops engraving after framing
The laser works when I do framing. When I start to engrave
It disconnects. Someone have a fix?
Do you see any error messages in the Console Window?
If there are error messages, please copy and paste them back to us.
If you start a very simple ‘line’ mode job like a square do you get the same problem?
What happens if you set the power to 0%?
I’ve had similar things happen & the way I fixed it is to scan for duplicates. If you do discover you have some delete them & it should cut as normal.
