X/Y Flipped on New Account
I have tried every fix I can find with zero luck. I have tried uninstalling and reinstalling, switching $3=0 to $3=7, and every other easy fix I can find. When I flipped the axis the Y was fixed but the X was not. Z is perfectly fine.
I am using a FoxAlien 20W laser. I wanted to use my FoxAlien controller but with all these issues I switched to my computer (Surface Pro) which did not fix the problem.
Any help would be greatly appreciated.
Grbl 1.1h [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
error:9
G-code locked out during alarm or jog state.
[MSG:Caution: Unlocked]
ok
Homing
[VER:1.1h.20201218:]
[OPT:V,35,254]
Target buffer size found
ok
ok
<Idle|MPos:-377.000,-377.000,-47.000|Bf:35,253|FS:0,0|WCO:-347.000,-367.000,-63.000>
ok
Starting stream
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
On or near line 0:
[MSG:Pgm End]
On or near line 0:
On or near line 0:
Stream completed in 0:00
[MSG:Check Limits]
ok
ok
ok
Starting stream
ALARM:3
On or near line 0:
[MSG:Pgm End]
On or near line 0:
[MSG:Check Limits]
ok
$0=10
$1=255
$2=0
$3=0
$4=0
$5=0
$6=0
$10=3
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=7
$24=25.000
$25=1000.000
$26=250
$27=3.000
$30=10000
$31=0
$32=0
$100=80.000
$101=80.000
$102=1600.000
$110=2000.000
$111=2000.000
$112=500.000
$120=300.000
$121=300.000
$122=30.000
$130=380.000
$131=380.000
$132=50.000
As a start try this setting with your original GRBL settings.
