X,Y value showing negative value
my laser is set to HOME in the front left corner. After homing I click get position and I have X: -748
Y: -748 when it should be X: 0 and Y: 0…
When I send the laser to the back right corner it IS X: 0 Y:0 but that is NOT my homing spot… how do I change this so HOME (front left) is 0,0 ?
I don’t want to leave you hanging.
Home the laser.
In the Console window type the following:
G10 L2 P1 X-748 Y-748
then press Enter.
then type:
$10=0
and press Enter.
Let me know if that works.
I believe this is covered here:
i found that thread that was about someone’s Y axes was doing the same thing, I did that and it didnt work. I did not try it like you are showing… Ill get right back with you.
Thanks
fixed it in 30 seconds!! thanks. I the other thread had doing the $10=0 first then the G10 stuff
Thank you very much!
