When using Lightburn the crosshairs stay lit all the time during the job run. Using Laserbox Basic the crosshairs do not light up during the job run.
I haven’t heard of this before.
Can you tell me which Firmware your xTool D1 is running and which version of Laserbox and LightBurn you’re using.
I believe that the command to turn the cross-hairs on and off would be visible in the G-code sent by each application.
I’ve never used Laserbox - is it possible to export or save the G-code for your project?
I’ll probably download it to help test this but i’d like to make sure it’s the same version.
If you generate a small job with one simple square and repeat the unusual behavior of the crosshairs in LightBurn you can export a small g-code file for review.
In LightBurn click File then about halfway down it’s Save GCode.
You can select the .txt file extension and review it or post it here in a reply.
If you can share both sets of generated GCode we may be able to find a solution or a workaround.
