Xtool D1 Pro extended working size results in laser no moving the correct size
Xtool D1 Pro with extensions - I have loaded and updated the device settings working size - display is correct and laser works until I reload the device setting (change between devices) or exit and restart LB. The working size setting remains, the display area is correct, if I frame or print, device moves in a “shrunken” size. Believe to be 1/2 of the actual entered size. Can only correct by reloading device setting and not adjust the working size.
