Hi all
i had to replace my main board in the XTool D1 Pro, it works fine but is not cutting the size correctly in the Y direction, i created a square 50mm x 50mm in lightburn and cut it out it when measured it was fine on the X axis at dead on 50mm but Y was 57mm, I then did the same using XTool Studio and the squre was fine at 50 x 50, any one help me solve this
Without knowing anything more, make sure Rotary Mode is Off:
If that’s not it, you may be able to reload the Machine Settings from an automatic backup made before the original board failed:
Hi all
i had to replace my main board in the XTool D1 Pro, it works fine but is not cutting the size correctly in the Y direction, i created a square 50mm x 50mm in lightburn and cut it out it when measured it was fine on the X axis at dead on 50mm but Y was 57mm, I then did the same using XTool Studio and the square was fine at 50 x 50, any one help me solve this
It Looks like that may have been the issue rotary switched on but I will test tomorrow thanks for the reply
All sorted now thanks
