Trying first use of an Xtool D1 Pro with the limit switches. firmware is updated and lbprefs loaded. Using absolute coordinates.
When powered on the laser homes to the back left. Yet the work space shows origin (green & red) as front left. If i try to process a shape the alarm goes complaining of limits exceeded.
Anyone know why it is using back left instead of front left as home?
How did you setup your device? Did you use the .lbdev file provided by xTool? If not, you’ll need to make sure the Origin setting is correct for your device. Go to Edit->Device Settings and make sure Origin is set to top-left.
