Xtool D1 Pro "stuttering"
I am engraving white tils painted black. Up unitil recently i was acheiving great results with a setting of 300mm/s and 80% power. Now I find the laser head slows down when engraving and makes a thud sound. This is not occuring in one place on the bed. I have repositioned several times. I have checked drive bands and movement is smooth on x and y axis. It occurs on different images. I have reset with tool for D1 Pro and Lightburn.
Any suggestions or ideas welcomed
I had this problem and found that it was because there were too many nodes in the DXF I was using. It went away when I used the “Optimize Shape” tool, and the number of nodes was greatly reduced.
I am engraving a png
You can save and upload a project file to examine, but it almost sounds like you have the interval/DPI too low.
Depending on what is in the image, the effect may change. Darker areas will have more dots and could cause stuttering, where lighter areas have less and will be fine. If you’re using a USB cable, try another cable or port, or simply unplug and replug to clean the connection.
Leon and Jen.lbrn2 (1.9 MB)
Nothing particularly egregious pops out at me. What’s your machine settings look like? Also go over all your motor plugs and reseat them. If the machine has sat awhile, they might have a little oxidization and be cutting in and out.
