I am having the same issue. When the configuration file is imported , does the upload switch need to be on? If so, how does this affect Creative Space operation with a xTool D1 Pro?
You don’t need to flip the upload switch before importing the configuration file provided by xTool in these instructions:
After following the above instructions - and making sure XCS is closed and not holding onto a connection - you may need to close LightBurn, turn your laser off and on again, restart LightBurn, and then manually select the correct COM port from the drop down menu in the Laser window
You’ll see a response in the ‘Console’ window when you’ve selected the correct port.
yep that worked . Thanks for the input!
