Y and X axis issue
Please make sure to answer each question discretely.
Also, based on your previous reply, it’s clear that the machine is not in fact homing correctly. Check the X-limit switch. Is the laser head resting on the switch and not sufficiently pulling off?
If it’s easier take a video of the homing process. You can’t upload videos here but you can upload them elsewhere and link here.
ALARM:9
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
ok
Grbl 1.1 [‘$’ for help]
Your Grbl may not support Variable Power mode (M4)
If your laser does not turn off between cuts,
switch to the GRBL-M3 device
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
