Y-axis faster than X-axis
Hi guys
I have a small problem with my laser.
I just calibrated my laser’s axes. Now I’ve noticed that the Y-axis is running faster than the X-axis.
How can I fix this?
Thanks in advance.
Check the machine settings if those are equal.
Where do I have to look?
Either send $$ in the console window and post the result or open edit → machine settings window and check the outputs section.
X-steps per mm (S100) is at 79.404.
Y-steps per mm (S101) is at 141.448.
I think it used to say 100 everywhere.
Auf Verbindung warten …
�ok
ok
[VER:1.1h.2022070601:]
[OPT:VZ,15,128]
Target buffer size found
ok
$0=10
$1=25
$2=0
$3=0
$4=0
$5=1
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=3
$24=300.000
$25=3000.000
$26=250.000
$27=1.000
$30=1000.000
$31=0.000
$32=1
$37=1
$40=2
$100=79.404
$101=141.844
$102=80.000
$103=100.000
$104=100.000
$105=100.000
$110=6000.000
$111=6000.000
$112=6000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=1000.000
$121=1000.000
$122=1000.000
$123=200.000
$124=200.000
$125=200.000
$130=410.000
$131=400.000
$132=200.000
$133=300.000
$134=300.000
$135=300.000
ok
Set $101=80
This depends on your mechanics. The most common value is 80 steps/mm. Though, there are also mechanics using 100 steps/mm. Set it to 80, then engrave a shape at a known size and measure if the output is correct.
Thanks
100 in X and in Y is the correct value.
