New user here. Have MecPow x3 with Lightburn on HP Pavilion Windows 11.
It appears that my laser is only engraving and cutting along the X axis.
It doesn’t matter if it’s a name tag copied from a tutorial, a simple shape, or a svg file. All I get is a laser thin cut.
The laser head is going through the motions but only horizontally.
Any advice?
Dskall
(D Kallenberger)
August 18, 2024, 4:15am
2
Check for bad connections.
parsec
(FerAS)
August 18, 2024, 5:23am
3
You could also try your laser reset button.
Thanks. As I was checking the connections, I noticed that the person who assembled the MecPow did not thread the rubber track over the gear spindle. Problem solved.
Thanks. Good suggestion. I noticed that the person who assembled the MecPow did not thread the rubber track over the gear spindle. Problem solved.
system
(system)
Closed
September 17, 2024, 7:06am
6
