sculpfun s9 upgrate kitt 33w laser,i have a problem whit the Y axis it going the wrong way.
enybody know how to fix this problem (runing latest version lightburn).
If it was working before the extension upgrade, and you have not fiddled with any parameters other than $131, then there is a very good chance you have one of the extender cables plugged in backwards.
Thanks, Mikey.
Problem solved; the Y-axis $2 setting was disabled.
The final issue is that the machine coordinates for the X and Y axes cause the machine collide with the frame.
How do you set the coordinates for a 400 x 410 workspace . I entered these in Lightburn.Perhaps you know a solution for this?
0 here does not mean “disabled”.
Did you make a backup copy of your machine settings (GRBL parameters) before changing them? You can do that in the Machine Settings window.
You said you added an extension, but those numbers are close to the original size, I think. The S9 and S30 have similar work areas.
Tell us what you had before the extension, and what it should be afterwards.
And one more thing, Welcome to the Forum!
S9 400x410 now the setting is 375 x 385 it working perfect.maybe in the future i gone expand the frame.
Thanks for helping me.
Glad you are up and running. Don’t to save those parameters.
