I am using a YoraHome 6550 40W laser and I frame the job and it lines up on the work piece perfectly and I will run the job. It starts where it is suppose to but after a few minutes it goes way outside of the frame it had ran. I am very new so I am sure it is just something wrong I am doing.
A photo of what you’re dealing with may help to understand the problem. In this case, it sounds like your belts may be slipping or your stepper motors are skipping. Check belt tension. If your speeds are higher than let’s say 6000 mm/minute then try running slower.
My settings are 60% at 800 and I clicked frame and it was all on the workpiece. The tensions look good and tightened just to make sure. I tried to attach a picture, ill have to do it via my pc i guess.
This should work on mobile as well. Push the up arrow icon.
60% at 800. Is that mm/min or something else?
If belt tension is fine, it could also be that your pinion gears are not properly secured.
