Z axis control between cut passes
Assuming that i have cut optimization by layer and i have only 1 layer with multiple passes to cut, is it possible to move the Z axis to raise it between one pass and the next with a pre-set distance?
Check the option “Z offset per pass” in Cut Settings.
Ok, got it, i will check, thank you
