Can someone help me understand what’s happening in Lighburn when I activate Z axis control option? I have Boss LS1630 (Ruida based). Been cutting with Lighburn without any issues, until I tried enabling Z axis in settings. Now before it starts cutting it tries to move my table all the way down for no apparent reason… I barely had time to press emergency stop before it lowered all the way down…
Z-offset of the material is set to none. I auto-focused manually prior to cut
When using Z control, you have two options:
- Set the material height using the ‘Material (mm)’ entry box under the cuts window
- Set the ‘Relative Z moves only’ toggle in the device settings
Ruida controllers only allow absolute Z moves during a job, so I have to know the height to use. The ‘Relative Z moves’ toggle means that when you start or send a job to the controller, it reads the current Z value from the machine and offsets everything by that, so it’s simpler to use, but you must be connected to the machine to use it.
Awesome, setting it to Relative mode helped!
