Hi,
If you do not have “pen focus” installed, it is not possible to manage the Z axis from LightBurn?
Thanks for the possible clarification.
Hi,
Yes, assuming the hardware you have supports it. (Ruida does). Go to Edit > Device Settings, then enable Z moves, Relative Z Moves only, and Optimize Z moves. (most people want all 3)
Then you’ll be able to set Z offsets in your cut settings, and those will be movements relative to the starting Z height that you choose.
