I get the following error when I try to home the laser.
ALARM:9
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
ok
Grbl 1.1f [’$’ for help]
[MSG:’$H’|’$X’ to unlock]
$X
[MSG:Caution: Unlocked]
ok
I do not have limit switches installed (on order). Is there a way to set the z axis? I don’t want it to move once I’ve focused the laser. Everything works when I use LaserGRBL.
