Z Axis issue when using "Ctrl +Z"
After the recent upgrade to 0.9.16 I have noticed that you can only move the Z position a minimum of 2mm at a time, previously you could configure this to what you wanted when using “Ctrl +z”. to adjust the Z height. I have tried changing the numbers and I cant seem to ever get anything but 2mm at a time when using “Ctrl + z”. Please advise if Im doing something wrong.
Thanks
Do you mean pressing Ctrl + the Z key on the keyboard? (as that’s the “undo” shortcut)
What version did you have before? Do you have ‘Continuous jog’ enabled, by chance? That would move based on the length of time you hold the button.
I had 0.9.15 and Im referring to the MOVE window on the right hand side… where you can click to raise or lower Z. Please see attachment… Previously I could move this in 1mm adjustments… Z control
You see there where it says “distance”? That’s how far it’s going to move when you click. Holding Shift when you click will multiply that distance by 5. Holding the Ctrl key when you click divides by 5 (there’s your 2mm). Holding Ctrl+Shift when you click divides it by 10, and holding Alt will divide it by 50, but it’s all based on the Distance number in that box to start with.
Had NO idea about that… Im guessing my other was set at 5 previously after looking at your break down of that. Thank you very much for the explanation!!
