Z Axis issues w/ WeCreat Vision 40W
Hello everyone,
I have a WeCreat Vision 40W. I managed to get it mostly working with LightBurn but am having a few issues. I installed the custom profile I found on this forum.
My first issue started when trying to perform a camera calibration. I can successfully run the calibration, but I can only run it with the Z axis at the highest point. If I try adjusting the Z axis prior to running the calibration (whether it be with autofocus or manually) it will scan twice, then stop.
My second issue is when I try to perform an interval test. I will manually set the Z axis, but when it starts, the laser head will lift from where I set it, then just stop altogether. I don’t seem to see any sort of “material thickness” settings within the interval tool, so how am I supposed to properly set the Z Axis prior to the test, and how do I prevent the Z axis from raising when starting the test?
This is my first machine so I apologize in advance for my ignorance.
Any help will be appreciated!
Select Edit>Device settings and you have a few Z options.
These are the settings I have for the Z Axis. Please let me know if anything’s wrong.
