Hi I’m new to co2 laser I have a OMTech polar running but can’t get the z axis to work. I can move it manually with the buttons but when I load a program the z axis does not come down also when I press the focus button the z axis just comes down and stays down. I was hoping someone would be able to give me some advice as to what I’m doing wrong
Thanks
Rich
There should be a setting in the controller to enable/disable focus.
Thank you for your reply it’s really appreciated would that be a setting on lightburn or do I need to find a driver to install on lightburn ?
Look here to start:
Thank you so much when I get in I will give that a go. Thank you for your support your a star
Short answer is (in LightBurn) to look under Edit | Machine Settings | Miscellaneous for the field called “Focus Enabled”. That needs to be verified as set to “True”.
Since you’re a newbie, might I suggest you look through the LightBurn Documentation when you have a quiet evening. It’s a really good place to start as are the YouTube videos.
All else fails, don’t be afraid to ask here. There’s a plethora of folks that are always willing to help!
Cheers!
Thank you. Ive Started Reading Through and watching the videos but need to do more homework. Thank you so much for your support
Cheers
