Z axis question
Hi, I wonder does Z axis is really important in cutting plywood 3 mm. ? I have diode laser, I focused it on the top of the surface of plywood, but sometimes cut is not full. Maybe I should focus on bottom of the plywood ? I use air assist. What do you suggest ?
I’d recommend setting the focus to the middle of the material.
