Hello I am not sure if this is the right place to post but here I go.
I am trying to setup a XYZ homing so that the newly purchased Cloudray autofocus can work with my board,
I am just not sure where I find these settings in Lightburn so that I can get this to work.
I am not sure if this is a function of Lightburn or the board manufacturer , all I want to happen is when I home, the bed elevates and the autofucs touches the work surface, records that height and then bounces back to the 50.8 focal point height and then carries on and does XY homing and is all set to go.
I am going to assume here that the autofocus is a one off setting per homing cycle and does not automatically allow for different surface heights if the work surface is textured or of uneven height, I guess that would be a miracle if that would work
I can not seem to find any setting for this in my version of Lightburn, I use a VMS board . I saw in a another video that this āoffsetā was in Lightburn where you had a Ruida controller or am I wrong on that?
Does anyone have any knowledge please on how you should set this device up in Lightburn please. I am new to this type of device so please forgive my ignorance. I have tried in vane online to set this up and I have not been able to get any further than using it just as a stop when it hits the work surface.
Thank you.
