Using Lightburn on the Marlin configuration with the ramps board and have noticed the z steps are not implementing on the cuts.
We set z steps per pass at an exaggerated amount (7.5mm/pass + 5 passes) in order to verify the direction the z is moving and found it is not moving. The motor is also not engaged on finishing the moves.
All axis can be moved using the move console so seems odd why this function is not working…
