Zbaitu 20w engraver with risk between one recording and another
When I use lightburn’s matrix option there is a risk when the engraver goes to work on the other duplicate design.
If I send it to record individually, the problem doesn’t happen.
Can someone help me, please?
Reduce the maximum speeds for the X and Y axes (the GRBL $110 and $111` values) by a factor of ten to see if the problem Goes Away. If so, then the speeds were higher than your laser can handle.
You can then increase the speeds until the problem returns, at which point you should reduce them by a factor of two.
Thanks, I’ll try this
