My 02 RED began to have skips when cutting. I checked the file I was using and it isn’t the file. I finally switched cutting to 10 and no more skips when cutting. Not sure what is going on.
10- m/h?? m/s or 10 Watts or…
Help us help you
Perhaps this will help identify the problem:
Also, make sure Perforation Mode or Tabs / Bridges hasn’t been (inadvertently) turned on in that layer.
If those don’t fix it, some pictures of the problem will help us see what you’re seeing.
Sorry I forgot to include watts. It is a 10W Atomstack
The 10 refers to the numbered levels or whatever it is across the bottom of the screen. It is maroon colored and is numbered 10.
If it’s the layers you’re referring to, then you decide for yourself what parameters they contain.
May I ask how familiar you are with LB? We can take it from there.
