Since the update to the current version my laser control command setting to Inline not set in gcode and replaced by M106/ M107 commands but Inline is set!
Then I am forced to go to the settings and set to M106 or M03 and back to Inline to get the S Values in the G moves again in the exported code.
Even after an update from 1.0.04 to 1.0.06 the same issue exists.
I didn’t understand this post but assume it’s related to Marlin. Is the generated g-code the same whether or not inline has been selected? Can you pinpoint the specific version when things changed?
Don’t know if the change was deliberate but perhaps downgrade to an older working version until the problem is resolved.
So essentially you’re saying the issue is that the setting to use inline for Marlin devices is not respected after a restart of the application starting from v1.0.04? But that inline continues to show selected.
Can you confirm that going back to 0.9.24 eliminates this problem?
Not sure if it’s related but I noticed a different problem where display text size changes did not survive an application restart. This has been recognized as a bug.
Yes, with the old Version 0.9.24 this issue do not exist, I do not have any other version between the 09.24 and 1.0.04 to test on which version exactly this issue appears.
You are posting on a community forum, and we unfortunately can’t read every message here (though we do try). If there is something that you feel requires a response, it is best to email support@lightburnsoftware.com
I will have a look and see if I can reproduce this.
