think I found it. use selection origin wasn’t selected after the update. I selected it and seems to be ok. getting ready to try and burn it. will update in a few.
That’s telling us only what you think it isn’t doing, but nothing specific about what you’re actually seeing it do, or why you think it’s wrong.
You have to tell us what it does do that you think it shouldn’t be doing.
It’s worked as intended. I didn’t have the “use selection origin” selected. I didn’t uncheck it before the update. anyways after the update, it wasn’t checked. I didn’t make any changes to file and just reloaded a file that I had previously used. I checked "use selection origin: and it cut the file as intended.
OK, if I draw a big square 300x300mm put it on T1 or T2 and draw a small square inside it 20x20mm on any layer. Version 1.2 will frame around T1 or T2. Version 1.3 will NOT frame around T1 or T2 just around the 20mm square. I know this because I use T1 or T2 for framing my material all the time.
I downloaded the old version and still the same problem now… this is a big issue.
What version and what problem are you having?
Downloaded 1.3 version and the framing is at a crawl. So i uninstalled lightburn and reinstalled 1.2.4 version and still having the same issue.
Check this post here:
