1.3.00 There was a problem sending data to the laser
I just installed the latest Lightburn 1.3.00 update and I am getting the “problem sending data to the laser” error. I am using a Snapmaker A 350 and everything was fine until the upgrade. The machine is connected through USB and communicating with the laser. I can control it by typing Gcode into the console but none of the regular laser controls work. Frame, Home, and Origin do nothing and when I hit Play I get the data send error. Does anyone have any suggestions?
I’m about ready to uninstall the update but I don’t want to lose my machine settings.
Thank you and yes, we are aware. We just posted this to the top of the forum for others to see. :slight_smile:
Hi LightBurners! We’re aware of a communications issue with GCode devices with the recently released version 1.3.00. At this very moment we’d suggest NOT upgrading LightBurn while we await a fix to be pushed.
As always, you can downgrade LightBurn from our releases archive here: Releases · LightBurnSoftware/deployment · GitHub
This post will be updated as needed with more details. Thank you for your patience.
You can downgrade to a previous release without loosing your settings.
I’m glad it wasn’t me, it was driving me crazy? Will I need to reinstall my machine settings if I downgrade?
:slight_smile:
Just download and install, all should be preserved.
I just did that and it is working again. Thank you
fix has been posted, you can try again now :slight_smile:
how do i know what version I previously had ? I’m having the same problem. i tried 1 of them and the laser power isnt the same.
You don’t even have to downgrade - you can just re-download 1.3.00 and re-install it. A piece of code got pulled into this release that wasn’t intended to be, and wasn’t ready, but that was quickly pulled and updates have been posted.
thank you, much appreciated
