1.7.03 MAC Pro Ventura 13.6 DXF Export issues
I often export to DXF. Today I upgraded to 1.7.03 and the DXF export function doesn’t work in AutoCAD light. It comes up with a check box and asks one to press enter to continue (never done this before_ on pressing enter nothing happens.
On my Dell 64 bit Windows 10 running 1.6.03 the same files export with no problem
Are you making a selection of what you want to export before selecting export? That works for me.
See if this tread is somehow linked to the problem you have.
No I want and need to export the full file. As stated this does work in an earlier version.
Can you attach two DXFs of the same project? (One that works from 1.6.03 and one that doesn’t from 1.7.03)
The only thing that I can recall being added to the exporter is proper layer information, which was added because Wazer’s waterjet software wouldn’t import files without it.
