1.7.08 vs 2.0.02 software issues
ok, so since I have upgraded to latest version I have had com issues, restarting com suragate from task manager seems to fix the problem also in version 1.7.08 framing starts left to right then around and 2.0.02 goes from front to back left side then around. I have had laser stop mid stream and just stay there. I had also noticed it lock up if I hit frame a few times. I have replaced the USB cable with a brand new one and nothing else has changed since changing versions.
Do a clean install. Add the laser again. Then try again.
did a windows uninstall of lightburn and reinstalled, license info intact after reinstall, clicked on devices and deleted device and recreated it, restarted lightburn and still issues, framing goes from left front to left rear and so on. laser often stops moving during job, laser goes off when it stops moving except one time it did stay on. 2.0.00 does the same thing with framing, front left to back and around.
