14watt dual diode J Tech laser on a Onefinity CNC
What light burn software should I buy for this set up?
Judging from the end view of the controller box connectors, it’s a Raspberry Pi atop a CNC driver board turning G-Code into motion.
It might have a GRBL derivative on the driver board, but it’s not clear you get direct access to it, which means LightBurn can’t run it directly. Instead, you’d use LightBurn to generate a G-Code file, transfer the file to the controller, then run it from there.
At least that’s what a quick search for “LightBurn” suggests.
