150 names inside shape
Help from pros, please!
Whats the best method to place 150 different (single) names inside a unique shaped object? The shape of the object will be the same throughout the project.
The origin of the names are coming from a word doc. My current method is using Adobe Illustrator:
However, this process takes way tooooo long.
Is there a more effective process?
Immediately, I think about Variable text from CSV
You should be also able to use the Shape Properties on the text to limit its max width if necessary
I think is possible to do via Variable Text function
@R_Salv
As a case study, could you provide a few names and that LBRN and see what we can come up with
I am sure LightBurn has a way to achieve this :slight_smile:
