16mp Camera problem osx
big sure osx
The camera works without problems in the Photo Booth app.
When I start lightburn (in 1.6.0 and 3 versions ago) it does this:
log from terminal:
2024-04-18 12:48:44.315 LightBurn[47170:1063888] NSDocumentController Info.plist warning: The values of CFBundleTypeRole entries must be 'Editor', 'Viewer', 'None', or 'Shell'.
Using the core prefs dir
QMetaObject::connectSlotsByName: No matching signal for on_actionEdit_GameControllers_triggered()
connected
Duplicate entry?  This shouldn't happen
"en0" "en0"
"en2" "en2"
"en3" "en3"
"bridge0" "bridge0"
"llw0" "llw0"
"utun0" "utun0"
"utun1" "utun1"
"utun2" "utun2"
"utun3" "utun3"
"16MP USB Camera" "0x1431000032e40298"
"FaceTime HD Camera (Built-in)" "0x1450000005ac8511"
Setting camera to  "0x1431000032e40298"
res: 640  x  480
res: 800  x  600
res: 1024  x  768
res: 1280  x  720
res: 1280  x  960
res: 1600  x  1200
res: 1920  x  1080
res: 2048  x  1536
res: 2320  x  1744
res: 2592  x  1944
res: 3264  x  2448
res: 3840  x  2160
res: 4000  x  3000
res: 4160  x  3120
res: 4208  x  3120
res: 4656  x  3496
default: 2320  x  1744
Setting res: 4656  x  3496
res: 640  x  480
res: 800  x  600
res: 1024  x  768
res: 1280  x  720
res: 1280  x  960
res: 1600  x  1200
res: 1920  x  1080
res: 2048  x  1536
res: 2320  x  1744
res: 2592  x  1944
res: 3264  x  2448
res: 3840  x  2160
res: 4000  x  3000
res: 4160  x  3120
res: 4208  x  3120
res: 4656  x  3496
res: 640  x  480
res: 800  x  600
res: 1024  x  768
res: 1280  x  720
res: 1280  x  960
res: 1600  x  1200
res: 1920  x  1080
res: 2048  x  1536
res: 2320  x  1744
res: 2592  x  1944
res: 3264  x  2448
res: 3840  x  2160
res: 4000  x  3000
res: 4160  x  3120
res: 4208  x  3120
res: 4656  x  3496
After a few tries of unplugging the usb it even starts working but not for long
res: 640  x  480
res: 800  x  600
res: 1024  x  768
res: 1280  x  720
res: 1280  x  960
res: 1600  x  1200
res: 1920  x  1080
res: 2048  x  1536
res: 2320  x  1744
res: 2592  x  1944
res: 3264  x  2448
res: 3840  x  2160
res: 4000  x  3000
res: 4160  x  3120
res: 4208  x  3120
res: 4656  x  3496
Hi Dean!
Couple questions, please
  • what version of LightBurn are you running currently
  • You said nativly on the OS, the camera works perfect yes?
  • does the camera gets identified when trying to run the wizard?
  1. Now I tried beta 1.6.00. I’ve had the camera for about 3 months and it doesn’t work for me with any version of lightburn.
  2. On imac with big sure it works fine with PhotoBooth application.
    When I start LB, the picture is also distorted in PhotoBooth (attached picture)
  3. After several attempts to turn off and on the usb from the camera, I even did a camera calibration.
The camera sometimes works for 5min, 20min, differently, when I start LB it always snaps (zigzag) the picture
