Computer updated lightburn to the newest version while away over the weekend. I am trying to run the exact program with identical settings as a known good file. I have tried changing the fill mode and always get the same preview. I also tried to run one pass thinking maybe the preview was incorrect but unfortunately that is not the case. I have 3 identical jobs that I need to run on a deadline that were working perfect before the update. We are also experiencing another different issue on a separate job where our machine was dialed in to run 4 of the same items in a batch that is no longer working and seems as though the laser calibration is off. It will engrave close to the center but will not mark within +/- 35mm of the 110mm boundary. Known good file and was used to run HUNDREDS of pieces flawless prior to update. Very frustrating considering both of these jobs are time sensitive. Any advice or guidance welcome.
Going to try going back a version to see if it fixes my issues.
Going back to 2.0.5 seems to have solved it for now.
This has been found and fixed for the upcoming patch release, set for Monday.
Sounds good, Was able to get it running on 2.0.05 and will continue until the patch comes out! Thanks
