Bonjour. je possède 2 lasers ORTUR. Les 2 se connectent sur mon ordinateur. Sauf que 'un des 2 l’autoguidage ne fonctionne pas. Alors que je branche l’autre il je ne rencontre pas de problème. Merci.
Hello. I have 2 ORTUR lasers. Both connect to my computer. Except that one of the 2 autoguiding does not work. While I connect the other there I do not encounter any problem. Thank you.
le cycle d’autoguidage n’est pas activé dans vos paramètres Grbl.
En attende de connexion…
[AUTHOR: RenShen]
[MODEL: Ortur Laser Master 2]
[OLF: 137]
[DATE:01:15:16 - Apr 20 2020]
[VER:1.1f.20170801:]
[OPT:VZD,35,254]
Target buffer size found
ok
Autoguidage
error:5
Voici e message que je reçois. Sauf que sur GRBL il fonctionne bien !
Would you please capture and share the similar message from your other machine?
this message occurs when the Ortur is asked to go home (homing cycle) but homing is not configured as an option in your engraver. I feel the options on your other Ortur will differ from this engraver. Can you verify that the following options are different.
[OPT:VZD,35,254]
To use the current engraver, you can turn off the offending command. It is a switch in this window.
