Is there a mechanism to draw a circle that satisfies 3-points, or a draggable-circle using two points?at
If it’s in a menu, I haven’t found it. If there is a method using existing tools, I haven’t found it either.
There isn’t, no. The functions you’re referring to are typically found in CAD applications, and are less common in graphic design apps.
I have a need, too. I have an arc in an image I want to cut. The arc is thick enough that the image trace traces around it. I’m going to try and get the coordinates of three points and do it externally.
