I am trying to run both of my Thunder Novas on one laptop. I know it can be done but one of them keeps trumping the other while trying to go back and forth. I have 2 seperate instances of lightburn opened and they’re plugged into a USB external port. PLEASE HELP!
Must have 2 separate USB ports on the PC. Can’t use the same COM number. Most reports indicate a USB hub does not work, but I think I read a powered hub did for a few.
Your fatal mistake is using USB. With an Ethernet connection it has to go to that specific address. Assuming they are both on the lan, you have to have different IP for each machine.
You can make two profiles, one for each machine with it’s IP address.
Could you describe what ‘trumping’ is exactly?
As long as both machines are ON constantly, and you pick the correct COM port with each LightBurn instance, you should be able to operate two machines just fine. It’s possible to overload a single USB controller if there’s a lot of data, but you should be just fine in most cases.
As @jkwilborn mentioned, if you can use a network to connect to both lasers, that’s a great way to both make your machines wireless and connect to multiple identical lasers with ease of separation (different IP addresses for each laser)
Could you possibly walk me through how to do this?
Or you can use a LightBurn Bridge: LightBurn Bridge - LightBurn User Guide - using a Raspberry Pi and a SD card + Power supply.
Not what you might think. ![]()
I think it means Run on one laser knocks the other offline.
@Colin is correct. I have used the Lightburn bridge but, a pair of thunderstorms knocked them out, as they got wet and I lost it’s wifi hardware.
The Lightburn bridge woks better as it has a layer of software that helps with communications to the Ruida.
Last one I had and lost, I replaced it with a $12 t-link bridge (at the time) from Amazon. A PI was difficult to find and was very expensive to replace, at the time. This particular router is likely not what you want as it only has one Ethernet port. Just an example of what you can get.
They’re pretty durable. Had mine since June of 2021.
The Lightburn bridge is nice in any event.
