20W Longer Ray5 upgrade installation issues
As has been discussed, Longer’s directions aren’t great. I have googled the dickens out of this and can’t find an answer.
I have a Ray5 10w and I am upgrading to 20W.
It has a MKS LTW v1.3 board I am trying to connect to.
The instructions call the TTL a single P and call what is labeled 12v on the new cable a 2p.
super helpful. when they are labeled 12v and TTL.
There are two 2wire 12v connectors on the upgrade cable. and they seem to be a split off a 4 conductors section of cable.
So before I connect the new power supply brick.
I am trying to confirm that one 12v goes into the top of the board near the x,y,y2 headers and the other goes on the side of the board in the 12v spot next to the 5v header.
This would make sense as it is 4x 5w lasers and 10W works on 12v so 12v and 12v would power all 4 lasers.
If anyone can confirm I would appreciate it.
If you could post a few photos of the modules you have and of the cables that came with the upgrade, that would probably help us work out how the whole thing needs to be wired up.
This is the board.
I don’t have an image of the cable, but the section in question is a 5 wire that is split into two 2 wire male leads labeled 12v and a single wire male labeled ttl.
I spent the night googling the heck out of it and some AI and I am pretty confident it is correct to connect the 12v connections to the two headers marked 12/24v (top and left edges) and the ttl.
Also Two Trees has a 20w that plugs in this way in a post I found.
Took the plunge, got first light tonight.
Seems to be working correctly.
Plugged in as described above.
Thanks for being willing to help Aaron.
Glad to hear that it worked out.
If you could post a picture showing how you’ve wired it up, that might help others.
