Hi I have created a text to a curve of a circle but cannot create another text to the same curve. Is this able toi be done. The option to create another text on path is greyed out once a text has been added to the path in this case a circle.
The trick is to duplicate the original curve (Ctrl-D), then use the duplicate to shape the second text line.
In that situation, Undo (Ctrl-Z) is my copilot: undo the bending, duplicate the curve, redo the bending, then type more text a do more bending around the duplicated curve.
You can also convert the first set of text to a path, which will allow you to apply the second set of text to the same path.
Or, you can always just use the Bend Text handle to bend both pieces to the desired placement on the path.
Thank you will try that
