Where can i but the cable that goes from my rotary to my engraver. I need a 3 pin to six pin and i can’t find one anywhere.
Might have to make one. What do the ends look like?
What laser do you have?
What rotary do you have?
Why can’t you take the Y axis cable and attach that to the Rotary? You need to disable the Y axis to run the rotary attachment.
Photos of the cable ends with explanations would really help.
The Left-Right move cable is the X axis.
You want to plug the Front to Back move cable to the rotary. What rotary to you have?
I have a longer
It concerns me that you are waving around a 3-pin connector. Where does the other end of that wire go? Stepper motors are usually 4 or 6 pin receptacles.
Unplug the cable from your Yaxis motor and plug it into the rotary stepper motor. You should have received a couple of 4 to 6 pin adaptor cables with the rotary if your Yaxis motor is 4-pin.
