3018 Pro not detected
Hi, my 3018 Pro is not detected from USB port under iMac Mojave OS.
all firmware are last version.
Thanks for support
Try doing a full reset of the Mac. I’m not sure which USB device the 3018 is using, but if it’s an FTDI chip, they have some known driver conflict issues on MacOS.
The demo version of Lightburn works perfectly under Parallel Windows 10, installed on my iMac.
Regards
I suggest you use that then. Windows does not have the driver issues that MacOS does - it’s specific to the operating system, not the hardware.
Hi, Afetr disintasa and reinstall software this is the result:
Process: LightBurn [527]
Path: /Applications/LightBurn.app/Contents/MacOS/LightBurn
Identifier: com.LightBurnSoftware.LightBurn
Version: 0
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: LightBurn [527]
User ID: 501
Date/Time: 2020-04-21 14:54:25.950 +0200
OS Version: Mac OS X 10.13.6 (17G12034)
Report Version: 12
Anonymous UUID: CBD947CF-1CDA-AA24-A06E-7321017FAD33
Time Awake Since Boot: 230 seconds
System Integrity Protection: disabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000048
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [0]
VM Regions Near 0x48:
__TEXT 000000010097c000-0000000101c16000 [ 18.6M] r-x/rwx SM=COW 4 [/Applications/LightBurn.app/Contents/MacOS/LightBurn]
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 org.qt-project.QtCore 0x000000010222ab6c QString::operator=(QString const&) + 28
1 com.LightBurnSoftware.LightBurn 0x0000000100b7fcc3 CameraControlWidget::on_cbCamera_currentIndexChanged(int) + 243
2 com.LightBurnSoftware.LightBurn 0x0000000100cf34af CameraControlWidget::qt_metacall(QMetaObject::Call, int, void**) + 63
3 org.qt-project.QtCore 0x00000001023aa876 QMetaObject::activate(QObject*, int, int, void**) + 2230
4 org.qt-project.QtWidgets 0x0000000102d5a743 0x102c40000 + 1156931
5 org.qt-project.QtWidgets 0x0000000102d5f191 0x102c40000 + 1175953
6 org.qt-project.QtWidgets 0x0000000102d5ee6e 0x102c40000 + 1175150
7 org.qt-project.QtCore 0x00000001023aab4a QMetaObject::activate(QObject*, int, int, void**) + 2954
8 org.qt-project.QtWidgets 0x0000000102d5cdcc QComboBoxPrivateContainer::eventFilter(QObject*, QEvent*) + 1244
9 org.qt-project.QtCore 0x0000000102379c62 QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*) + 210
10 org.qt-project.QtWidgets 0x0000000102c5098d QApplicationPrivate::notify_helper(QObject*, QEvent*) + 285
11 org.qt-project.QtWidgets 0x0000000102c5373d QApplication::notify(QObject*, QEvent*) + 7165
12 org.qt-project.QtCore 0x000000010237997f QCoreApplication::notifyInternal2(QObject*, QEvent*) + 159
13 org.qt-project.QtWidgets 0x0000000102c512d0 QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer&, bool) + 896
14 org.qt-project.QtWidgets 0x0000000102caa852 0x102c40000 + 436306
15 org.qt-project.QtWidgets 0x0000000102ca9300 0x102c40000 + 430848
16 org.qt-project.QtWidgets 0x0000000102c509a2 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 306
17 org.qt-project.QtWidgets 0x0000000102c51cbf QApplication::notify(QObject*, QEvent*) + 383
18 org.qt-project.QtCore 0x000000010237997f QCoreApplication::notifyInternal2(QObject*, QEvent*) + 159
19 org.qt-project.QtGui 0x000000010274e44c QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) + 2956
20 org.qt-project.QtGui 0x0000000102735b5b QWindowSystemInterface::sendWindowSystemEvents(QFlagsQEventLoop::ProcessEventsFlag) + 155
21 libqcocoa.dylib 0x0000000104d28aa1 0x104cfe000 + 174753
22 com.apple.CoreFoundation 0x00007fff35f42851 CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION + 17
23 com.apple.CoreFoundation 0x00007fff35ffce4c __CFRunLoopDoSource0 + 108
24 com.apple.CoreFoundation 0x00007fff35f252b0 __CFRunLoopDoSources0 + 208
25 com.apple.CoreFoundation 0x00007fff35f2472d __CFRunLoopRun + 1293
26 com.apple.CoreFoundation 0x00007fff35f23f93 CFRunLoopRunSpecific + 483
27 com.apple.HIToolbox 0x00007fff3520ed96 RunCurrentEventLoopInMode + 286
28 com.apple.HIToolbox 0x00007fff3520ea0f ReceiveNextEventCommon + 366
29 com.apple.HIToolbox 0x00007fff3520e884 _BlockUntilNextEventMatchingListInModeWithFilter + 64
30 com.apple.AppKit 0x00007fff334bba3b _DPSNextEvent + 2085
31 com.apple.AppKit 0x00007fff33c51e34 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044
32 com.apple.AppKit 0x00007fff334b084d -[NSApplication run] + 764
33 libqcocoa.dylib 0x0000000104d2789d 0x104cfe000 + 170141
34 org.qt-project.QtCore 0x0000000102375502 QEventLoop::exec(QFlagsQEventLoop::ProcessEventsFlag) + 418
35 org.qt-project.QtCore 0x000000010237a092 QCoreApplication::exec() + 402
36 com.LightBurnSoftware.LightBurn 0x0000000100982909 main_global(int, char**) + 1289
37 libdyld.dylib 0x00007fff5de68015 start + 1
Thread 1:: Dispatch queue: com.apple.root.user-interactive-qos
0 libsystem_kernel.dylib 0x00007fff5dfaf1fa mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff5dfae714 mach_msg + 60
2 com.apple.QuartzCore 0x00007fff412b625b CA::Render::Fence::wait(unsigned int, unsigned long) + 169
3 com.apple.QuartzCore 0x00007fff4129ecc4 CA::Context::commit_transaction(CA::Transaction*) + 1330
4 com.apple.QuartzCore 0x00007fff4129e475 CA::Transaction::commit() + 487
5 com.apple.AppKit 0x00007fff335e0c20 NSPerformVisuallyAtomicChange + 166
6 com.apple.AppKit 0x00007fff335ed87b __42-[NSAnimation(NSInternal) _runInNewThread]_block_invoke + 85
7 libdispatch.dylib 0x00007fff5de365fa _dispatch_call_block_and_release + 12
8 libdispatch.dylib 0x00007fff5de2edb8 _dispatch_client_callout + 8
9 libdispatch.dylib 0x00007fff5de30b2c _dispatch_root_queue_drain + 902
10 libdispatch.dylib 0x00007fff5de30755 _dispatch_worker_thread3 + 101
11 libsystem_pthread.dylib 0x00007fff5e180169 _pthread_wqthread + 1387
12 libsystem_pthread.dylib 0x00007fff5e17fbe9 start_wqthread + 13
Thread 2:
0 libsystem_kernel.dylib 0x00007fff5dfb928a __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff5e18020e _pthread_wqthread + 1552
Thread 3:
1 libsystem_pthread.dylib 0x00007fff5e180009 _pthread_wqthread + 1035
Thread 4:
0 libsystem_kernel.dylib 0x00007fff5dfb8d82 __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff5df33724 nanosleep + 199
2 libsystem_c.dylib 0x00007fff5df33586 sleep + 41
3 com.LightBurnSoftware.LightBurn 0x0000000100cf9ea5 0x10097c000 + 3661477
4 libsystem_pthread.dylib 0x00007fff5e180661 _pthread_body + 340
5 libsystem_pthread.dylib 0x00007fff5e18050d _pthread_start + 377
6 libsystem_pthread.dylib 0x00007fff5e17fbf9 thread_start + 13
Thread 5:: com.apple.NSEventThread
2 com.apple.CoreFoundation 0x00007fff35f255c5 __CFRunLoopServiceMachPort + 341
3 com.apple.CoreFoundation 0x00007fff35f24917 __CFRunLoopRun + 1783
4 com.apple.CoreFoundation 0x00007fff35f23f93 CFRunLoopRunSpecific + 483
5 com.apple.AppKit 0x00007fff335f8fc4 _NSEventThread + 184
6 libsystem_pthread.dylib 0x00007fff5e180661 _pthread_body + 340
7 libsystem_pthread.dylib 0x00007fff5e18050d _pthread_start + 377
8 libsystem_pthread.dylib 0x00007fff5e17fbf9 thread_start + 13
Thread 6:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fff5dfb8cf2 __select + 10
1 com.apple.CoreFoundation 0x00007fff35f5f70b __CFSocketManager + 635
2 libsystem_pthread.dylib 0x00007fff5e180661 _pthread_body + 340
3 libsystem_pthread.dylib 0x00007fff5e18050d _pthread_start + 377
4 libsystem_pthread.dylib 0x00007fff5e17fbf9 thread_start + 13
Thread 7:
0 libsystem_kernel.dylib 0x00007fff5dfaf24e semaphore_timedwait_trap + 10
1 libdispatch.dylib 0x00007fff5de3e94f _dispatch_sema4_timedwait + 72
2 libdispatch.dylib 0x00007fff5de3694e _dispatch_semaphore_wait_slow + 58
3 libdispatch.dylib 0x00007fff5de31e53 _dispatch_worker_thread + 251
Thread 8:
Thread 9:
2 libsystem_c.dylib 0x00007fff5df33618 usleep + 53
3 com.apple.CoreMediaIO 0x00007fff36ff13f6 CMIOGraph::OneOrMoreInputUnitsAreReadyToBePulled(bool&) + 580
4 com.apple.CoreMediaIO 0x00007fff36ff1d81 CMIOGraph::DoWork(unsigned int) + 471
5 com.apple.CoreMediaIO 0x00007fff36ff4543 CMIO::thread::QueuedTWorkThread::DoWork() + 125
6 com.apple.CoreMediaIO 0x00007fff36ffdc67 CMIO::thread::SignaledThread::ThreadLoop() + 227
7 com.apple.CoreMediaIO 0x00007fff36ffdb5a CMIO::thread::SignaledThread::WorkQueuedThreadCallback(void*) + 154
8 com.apple.CoreMedia 0x00007fff36ed7937 figThreadMain + 277
9 libsystem_pthread.dylib 0x00007fff5e180661 _pthread_body + 340
10 libsystem_pthread.dylib 0x00007fff5e18050d _pthread_start + 377
11 libsystem_pthread.dylib 0x00007fff5e17fbf9 thread_start + 13
Thread 10:
5 com.apple.CoreFoundation 0x00007fff35f62a63 CFRunLoopRun + 99
6 com.apple.cmio.DAL.VDC-4 0x0000000147a9bbd6 0x147a95000 + 27606
7 libsystem_pthread.dylib 0x00007fff5e180661 _pthread_body + 340
8 libsystem_pthread.dylib 0x00007fff5e18050d _pthread_start + 377
9 libsystem_pthread.dylib 0x00007fff5e17fbf9 thread_start + 13
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000608000471f80 rbx: 0x0000000000000048 rcx: 0x0000000000000005 rdx: 0x0000000000004b9f
rdi: 0x0000000000000048 rsi: 0x00007ffeef281208 rbp: 0x00007ffeef2811e0 rsp: 0x00007ffeef2811d0
r8: 0x00007fff96891048 r9: 0x0000000000000040 r10: 0x00007fff96891040 r11: 0xffffffffffffffff
r12: 0x0000000000000000 r13: 0x00000001026965a0 r14: 0x00007ffeef281208 r15: 0x00007fe31246eeb0
rip: 0x000000010222ab6c rfl: 0x0000000000010206 cr2: 0x0000000000000048
Logical CPU: 2
Error Code: 0x00000004
Trap Number: 14
Binary Images:
0x10097c000 - 0x101c15ffb +com.LightBurnSoftware.LightBurn (0) <6417337C-F488-32C4-9859-AB2E1EDF9204> /Applications/LightBurn.app/Contents/MacOS/LightBurn
0x101f32000 - 0x101f40fff +libusb-1.0.0.dylib (0) <5F8F11E3-1C73-3DAA-BF62-E2FB4A819F65> /Applications/LightBurn.app/Contents/Frameworks/libusb-1.0.0.dylib
0x101f51000 - 0x101f62ff3 +org.qt-project.QtMultimediaWidgets (5.10 - 5.10.0) <3F8635B4-757D-3361-9B46-8C832815F78E> /Applications/LightBurn.app/Contents/Frameworks/QtMultimediaWidgets.framework/Ver
You selected a camera, not a laser. And without a laser configured, LightBurn is trying to store the camera you chose with the laser you have selected, but you don’t have one selected, and it died. (this is a bug, and it has been fixed already, but you have to set up a laser before you can use the camera feature).
Sir, the camera is working right, is the laser not recognized from USB port!
If you have nothing selected here:
Then trying to select a camera will crash in the current release.
May I know if the Ligtburn works on Catalina OS or with other Apple System?
on my High Sierra is not working!
LightBurn works fine. The drivers for your laser are the issue. MacOS ships with a driver that conflicts with the drivers used by FTDI devices. It’s also possible that your board uses a CH340, which you might not have a driver installed for. I do not know which chip your 3018 uses for communication.
This is to fix the FTDI issue:
Ch340 MacOS:
https://learn.sparkfun.com/tutorials/how-to-install-ch340-drivers/all#mac-osx
Hi, thanks for support; I’ve installed OS Catalina and now it work perfectly!
Happy User!!!
