ive put my work size in. my laser seems to be going different places i will start work from middle and the starts at bottom any ideas thank im new to all this
Rick
(Technical Evangelist)
January 7, 2022, 6:51pm
3
For your setup, this is worth review:
The summary:
Turn on Laser Mode to get rid of the travel lines
You’re trying to move too fast, which is why you don’t get enough power
You need to zero the machine
3018’s are pre-configured for use as CNC machines, not lasers, so their settings and speeds will likely need to be changed to give you acceptable results with LightBurn.
To see the existing settings, you can type $$ into the console in LightBurn and press enter, or go to Edit > Machine Settings. Both are showing the same values, b…
system
(system)
Closed
February 6, 2022, 6:52pm
4
