Gdday all
i am having a hard time to get reliable camera operation…as in the alignment seems to move
looking closely the camera has some play with the 3d mount anyone else found this and how did you rectify it?
Gdday all
You might to include a link to the camera mount you used to help others diagnose your problem.
I also 3D printed a camera mount. make sure you tighten all screws. you could put hot glue to avoid it to change angle.
You can use a small piece of EVA foam to hold the camera in the mount securely, or a bit of silicone or hot glue.
yeah i stuck a bit of foam in under the camera seems to be a bit more solid now
i still have an issue where the alignment seems to be off from one use to another,.not by much but probably 1mm - any tips to improve this?
Make sure the laser lid is opening to the same (exact) place every time, and that you put the top of the material at the focus point of the laser before you do the capture update.
